Hi, I currently have IA15 Studio installed and I am attempting to upgrade to IA16. However, after "verifying the contents of this setup package", the dialog disappears and nothing further occurs. How can I track down what the issue is? I believe it does go all the way to the end. Again, this is installing IA (rather than any installer I am making).
I have 10 GB in my C: Drive. Could this be the issue? My %TEMP% folder is on a separate drive (D:) and this has 1 TB free.
I was using the 2 GB package with Runtimes.
Update. I tried the smaller Web package and it is now running. Maybe 2 GB is too much to verify?
Cannot install IA16?
Re: Cannot install IA16?
I tried the web version - and it seemed to make good progress, but now it is stuck. It has been like this for a couple hours. Help!
Dear Tofutim,
the package can require about 20 gb during installation ... if all features are selected.
I think that probably was it. I re-ran the Web version after it got stuck and everything went fine. Not sure why the 2 GB version failed though.
