InstallAware 16 ignores swedish characters
danielb
Postby danielb » Thu Jul 11, 2013 3:26 am
When I open a project created in InstallAware 9 in InstallAware 16 all non-english characters are ignored in the editor. By example the text "Sätt rättigheter för" is viewed as "Stt rttigheter fr". It seems like the encoding in the mia-files has been changed. If I correct the example above the text is now saved as "Sätt rättigheter för" in the mia-file.
Best regards,
Daniel Bengtsson
Hogia Business Accounting Products AB
Re: InstallAware 16 ignores swedish characters
Postby FrancescoT » Thu Jul 11, 2013 7:16 am
Dear Daniel,
Could you please post a very minimal project to demonstrate your issue?
I have just tried with initializing a custom variable as "Sätt rättigheter för" and I haven't found the same as you.
The variable is correctly displayed with a MessageBox or Dialog.
IA 16 full supports UNICODE and consequently, it doesn't use any kind of encoding.
By the way,
- did you use the "Unicode Upgrade Tool" to migrate setup projects from older InstallAware versions to Unicode versions of InstallAware?
