Unable to load plug-in library (Write to Logfile Plugin)
I randomly gets the error when I run a setup:
"Unable to load plug-in library. Please rebuild your project and make sure all required plug-ins are installed. Action skipped"
Randomly means that I got it, then I closed setup and restartet it and it was working without error, Tahe next time I got it again and so on...
When I get the message no log entry is done as it should be. On most computers the setup is working but on few the error comes randomly.
Any ideas?
Any ideas?
- unable load plugin.png (12.11 KiB) Viewed 15131 times
Re: Unable to load plug-in library (Write to Logfile Plugin)
... let me check.
Dear Alibaba,
I am not able to replicate what you reported.
By the way, which is exactly the plug-in you are using?
As I said in the Subject the problem is the write to logfile Plugin. Also no Log entries are made when the error occurs.
Dear Alibaba,
please excuse me (... probably I'm still sleeping this morning
) ... but I don't remember of any IA Write to logfile plugin.
could it be a third party plugin?
Ah okay, I think it is part of the Camelot-Plugin, sorry - my mistake
Okay but what can I do? Will IA assist me or do I have to contact the plugin developer? Who is it?
Dear Alibaba,
Unfortunately, if the problem is caused by the third party plugin iteself ... there isn't too much that we can do.
Where can I adress this issue?
Dear Alibaba,
... I suppose you can only try to contact the developer directly.
Try to verify if exist any contact information available with the plugin setup package.
