my installations installs some shortcuts to AllUsers (c:\ProgramData\Microsoft\Windows\Start Menu\Programs\).
If I wrap this installation into a .msi file (InstallAware Group Policy Wizard) then the shortcuts are installed only per user. The shortcuts are not installed to c:\ProgramData\Microsoft\Windows\Start Menu\Programs\ but to
c:\Users\<username>\AppData\Roaming\Microsoft\Windows\Start Menu
I didn't change anything in CMDLINE and the setup is the same that workes fine.
Tested on Windows 8.1.
MSI files does not install shortcuts for AllUsers, EXE does
Re: MSI files does not install shortcuts for AllUsers, EXE d
Dear Alibaba,
try with forcing the "ALLUSERS" predefined variable as TRUE.
You can specify it with the Command Line Parameters field of the GPW.
Yes I know that it helps, but shouldn't the .msi install the same way like the .exe?
Users browsing this forum: No registered users and 66 guests
