DF-Cryptography Plug-in available
Post complete new themes or wizard dialogs here.
digitalfarm
Post by digitalfarm »
new version 1.5 of DF-Cryptography Plug-in for InstallAware has been relesed.
The DF-Cryptography plug-in application offers the possibility to use sophisticated encryption functions in your InstallAware® setup projects.
Through an easy and intuitive user interface, it is possible to have access to several cryptography functions that are all available in a single dialog interface.
With the plug-in it is possible to integrate in your InstallAware® script cryptographic functions as:
- Encryption, Decryption, RSA key pair Generation, RSA File sign -verification, Hashing using various Hash algorithm, Random data generation and Secure data assignment.
The plug-in uses strong low level cryptographic algorithms, this gives you the opportunity to use the most updated techniques with protecting data.
A unique protection feature is integrated with the application to protect the generated InstallAware® setup package at runtime execution.
The runtime protection works as a shield against external attempts to track or monitor the setup process. This shield becomes active each time an DF-Cryptography plug-in function is executed from your InstallAware script.
What's new in DF-Cryptography 1.5 plug-in for InstallAware®.
- New Secure data feature.
This new feature permits to assign a litteral value or a random generated value, in a secure protected area.
This technique is particularly useful when using sensible data as passwords, or with any other value that should be kept protected.
To make harder any possible attempt to decipher the effective data value used with the script, each script value assigned as "Secure Data", it is stored within the internal setup database as Encoded Data.
This process uses a unique Custom Key to generate a masked encoded "copy" of the effective value data and most important, the custom key is never exposed in the generated setup database.
The new Secure data feature is supported with the plug-in's functions; Encrypt, Decrypt and Random.
Includes a project sample that demonstrates how to use Secure Data feature.
- Unicode support.
The plug-in now full supports UNICODE if used with InstallAware version 16 or higher.
Previous InstallAware ANSI versions are also supported by DF-Cryptography plug-in 1.5.
During plug-in setup package installation, just select the most appropriate plug-in version to install (UNICODE or ANSI), depending on the InstallAware version used.
The software comes with a comprehensive context-sensitive help. Just press F1!
A full functional trial version is available for 30 days evaluation.
For more info visit:
http://www.digitalfarm.it/en-GB/DFCrypt ... lugin.aspx
the Digital Farm®
Arezzo Italy
digitalfarm
New version 1.5.9.1
This new "1.5.9.1" version includes the following updates;
- new strong routine protection shield against external attempts to track or monitor the setup process.
- HI DPI support.
- full support of the most recent InstallAware major versions; X2, X3, X4 e X5.
The plugin full supports UNICODE and ANSI versions of InstallAware.
Tested on versions; 9, 10, 11, 12, 2012, NX, 15, 16, 17, 18, X2, X3, X4 and X5 of InstallAware and compatible with older InstallAware versions as well.
SECURE YOUR SETUP DATA!
For more details please visit; http://www.digitalfarm.it/en-GB/DFCrypt ... lugin.aspx
Licensed users of any 1.5 version of the plug-in can upgrade for free.
In case you installed a previous TRIAL version of the plug-in, you may need to renew your trial period (30 days) in case you want to try this latest version. To receive your 30 days trial extension please write an email to: [email protected].
the Digital Farm®
Arezzo Italy
digitalfarm
New version 1.5.9.896
Version "1.5.9.896" includes the following updates and fixes;
- fixed "Windows 10 10 creators update" compatibility issues.
- Support of InstallAware 23.00 (X6) and X6 Creators Update (23.1).
In case you installed a previous TRIAL version of the plug-in, you may need to renew your trial period (30 days) in case you want to try this new version. To receive your 30 days trial extension, please write an email to: [email protected].
The "DF-Cryptography Plug-in" full supports UNICODE and ANSI versions of InstallAware.
the Digital Farm®
Arezzo Italy
