Finish Screen with Express
worksimp
Post by worksimp »
I'm using Express 17. I'd like to include the Finish screen to give interactive closure to the install. My application requires the use of a just-installed environment variable (I understand that's not available with Express)...so I'd like to use the Finish screen without the checkbox to launch the application. How can I do that?
Re: Finish Screen with Express
Unfortunately, it is not possible with the Express edition ... you can include or hide a dialog in the project's dialog sequence, but you can't modify a dialog.
