Hello IA Developers!
After I have upgraded from IA NX to IA 18 I am experiencing an error in the predefined IA Templates, when running the setup in the language german.
There are objects with the property WordWrap mistakingly set to True. For example the option button MySelf in the dialog startmenu and the option button Modify in the dialog maintenance.
You get ugly effects, because the text wraps in a second line. Please fix it for new users.
WordWrap errors in UI Dialogs of InstallAware Templates
- IPC CI-ODAC Manager - InstallAware Wizard.png (52.12 KiB) Viewed 3309 times
Re: WordWrap errors in UI Dialogs of InstallAware Templates
... I can only report your notes to our development team.
Unfortunately, it is not possible to have a wrapping mode that fits correctly with any Language by default.
I really suppose that it is forcedly necessary to apply manual adjustment ... when required.
