18.05 crashes when dropping folders to the target dir.
bokkie
Postby bokkie » Fri Apr 04, 2014 3:15 am
I am getting endless miaa crash errors in the IDE. I think it's replicatable but hopefully others will confirm it.
The background: my target directory is set to say hard-coded, C:\MyFolder.
In the IDE, I select the folder containing the files and sub-folders where my files are I want to install. I add all the files from say, C:\Temp\MyFiles. In C:\Temp\MyFiles I have a number of sub-folders which aren't initially added. I select $TARGETDIR$ and drag those sub-folder into it, one by one. I have about 20 sub-folders to drag and drop. Two things:
1. I have to keep selecting $TARGETDIR$ each time I drag a sub-folder. If I don't, the IDE drops the folder into the one I last selected. If I drag the folder and hover over $TARGETDIR$ and release the button it must surely be the sensible assumption that the drop should go into the one I selected. It's like the IDE has a bright-light retinal imprint of the last folder I dropped. I don't think that's correct.
2. Anyway, I select $TARGETDIR$ every time :( and after I've dropped a few sub-folders into it, the miaa blows up, and I lose all the changes I've made. I've lost a lot of time this morning over this problem and now, I have to drag-and-drop, save, quit, drag-and-drop, save, quit after each because I can't trust the IDE to let me do all of them one after the other. :(
I'm not doing anything in the MSIcode so it's all down to what's going on in the IDE. I can't submit my project because it's too big. I'm reasonably confident it can be replicated if you create an installation from a folder containing lots of files and lots of sub-folders. Hope this helps.
Re: 18.05 crashes when dropping folders to the target dir.
Postby FrancescoT » Fri Apr 04, 2014 10:14 am
Dear Peter,
I am not able to replicate the IDE crash with dragging folders to the TARGETDIR from the IA IDE ... and I used up to 50 folders containing a lot of nested sub-folders.
However I found as you, that the initial TARGETDIR selection automatically changes to the last dropped folder... and I'll log a note about this.
Users browsing this forum: Bing [Bot] and 52 guests
