MSI code variable to VBScript
markoh3
Postby markoh3 » Fri Apr 04, 2014 4:58 am
Is it possible to use a MSI code variable in a VBScript?
If this is possible how should I handle this?
Kind regards,
Marko
Re: MSI code variable to VBScript
Postby FrancescoT » Fri Apr 04, 2014 10:21 am
Dear Marko,
how do you integrate the VB script with your project?
If it is an external file that you execute from the setup, you could pass an IA Variable to it as you do from command line.
markoh3
Postby markoh3 » Mon Apr 07, 2014 1:13 am
Hi Francesco,
The VBscript is integrated within the project as a support file.
Regards,
Marko
Postby FrancescoT » Mon Apr 07, 2014 10:22 am
... you could pass an IA Variable to it as command line parameter (using the RUN PROGRAM command).
markoh3
Postby markoh3 » Tue Apr 08, 2014 12:29 am
Hi Francesco,
Thank you for your reply.
Do you have an example how I could do this in MSI-code. I will try it by myself as well but it would be nice to see an example.
Regards,
marko
Postby FrancescoT » Tue Apr 08, 2014 11:02 am
Dear Marko,
it really simple ...
Set Variable MYVAR to 1234
Run Program $SUPPORTDIR$\myscript.vbs $MYVAR$ (WAIT)
The above example excutes the vbscript "myscript.vbs" (from SupportDir at runtime ) and pass an IA Variable to it as command line parameter.
The same code snippet as IA clipboard format;
~InstallAware Clipboard Data~
~Run Program~
~{CDF79D0B-FAF1-4374-8DA4-382F32ADBFFE}~
~$SUPPORTDIR$\myscript.vbs~
~TRUE~
~$MYVAR$~
~TRUE~
~Set Variable~
~{8E58E9BD-05BB-432E-A15B-70FA32EFBFE1}~
~MYVAR$MYAH$MYAH$FALSE~
~1234~
Users browsing this forum: Google Adsense [Bot] and 248 guests
