Hi , I have around 20 keys+values under one section in an INI file and trying to remove all the keys or rename the section at least so my server does not read this section any more.
I tried Reading all the ini file content via ReadAll from text and parse the strings and having a loop to edit ini file content using Line-> remove in a loop for that section each line . It reads all the line and I can get each key and value but at the end it just deletes one row and not all.
you can see below what I did:
Read from Text File #READALL\$TARGETDIR$\Server\SvrCnfg.ini into Variable FieldMapSettings (get EOF into Test)
Parse String $FieldMapSettings$ into Variables and FieldMapSettings1 (Split at first occurrence of pattern)
Parse String $FieldMapSettings1$ into Variables FieldMapSettings2 and (Split at first occurrence of pattern)
Parse String $FieldMapSettings2$ into Variables FieldMapSettingsEach and FieldMapSettingsRest (Split at first occurrence of pattern)
while Variable FieldMapSettingsEach not Equals loop
Parse String $FieldMapSettingsEach$ into Variables FieldMapSettingsKey and FieldMapSettingsValue (Split at first occurrence of pattern)
if Variable FieldMapSettingsKey not Equals
Edit INI File $TARGETDIR$\Server\SvrCnfg.ini, [FieldMap] $FieldMapSettingsKey$=$FieldMapSettingsValue$
Parse String $FieldMapSettingsRest$ into Variables FieldMapSettingsEach and FieldMapSettingsRest (Split at first occurrence of pattern)
wend
Anyone has any idea how to rename the section or remove all the keys?
Samira
Rename a section or delete all the keys in INI file
Re: Rename a section or delete all the keys in INI file
Dear Shamira,
Are you sure that in your loop sequence, the "Edit INI" command is effectively executed for each entry you want to modify? Did you try to debug it?
Yes, I added a message there and I can see it goes through all the lines but it just deleted one of the line at the end !
Tried this as well but still the same:
for each Element EachLine in $NEWLINE$ delimited Collection of $FieldMapSettingsRest$ do
MessageBox: , EACH LOOP : $EachLine$
Parse String $EachLine$ into Variables FieldMapSettingsKey and FieldMapSettingsValue (Split at first occurrence of pattern)
MessageBox: , KEY: $FieldMapSettingsKey$
MessageBox: , VALUE : $FieldMapSettingsValue$ is removed
next
next
Dear Samira,
could you please post the same code as "InstallAware Clipboard Format" within a "Code tag" along with the ini file?
In this way I can try to debug it.
~InstallAware Clipboard Data~
~MessageBox~
~{079496CF-81BC-4DD5-AAFD-7F3B9866E7EA}~
~end of main loop~
~0~
~1~
~Next~
~{B25804B6-2713-4F0E-BB6F-121BA56CBE1D}~
~MessageBox~
~{CB5FE7F0-C096-47C9-9E39-0445178EE6EC}~
~end of nested loop~
~0~
~1~
~Next~
~{6AA562D3-6772-4A00-82EC-F0FE42DAA87F}~
~End~
~{FD95F455-3B50-4BE0-9A52-3FCB1F5CB2C2}~
~MessageBox~
~{7023E687-D430-4EDB-9C6D-86F05FEF1A42}~
~EACH Key : $EachKey$ is removed~
~0~
~1~
~Edit INI File~
~{51AD4ED3-2D98-4E7A-A064-2B27B9D8A250}~
~$TARGETDIR$\Server~
~SvrCnfg.ini~
~2~
~FieldMap~
~$EachKey$~
~If~
~{D5E42BAE-2772-4031-B602-BE717D7B04A1}~
~EachKey~
~1~
~JOB~
~TRUE~
~For Each~
~{7D90E15E-B5FE-4DD2-B623-BF194B1FCCFF}~
~EachKey~
~$EachLine$~
~For Each~
~{70DF04D4-1816-43A0-B1E7-D506DA9E3014}~
~EachLine~
~$NEWLINE$~
~$FieldMapSettings1$~
~Parse String~
~{DE47E7E8-88C3-414E-9568-C67BD3AC8124}~
~$NEWLINE$~
~FieldMapSettings2~
~0~
~FALSE~
~FALSE~
~Parse String~
~{F27DADA9-A301-47CB-AAC0-1372EC0F8031}~
~$FieldMapSettings$~
~[FieldMap]~
~FieldMapSettings1~
~0~
~FALSE~
~TRUE~
~Read from Text File~
~{A23BFA6F-C92B-47A6-84E1-31373BD25E97}~
~#READALL\$TARGETDIR$\Server\SvrCnfg.ini ~
~FieldMapSettings~
~Test~
and in the ini file I have this :
[FieldMap]
RESTASK.MANAGER=JOB.JOB_MANAGER
RESTASK.ID=JOB.JOB_ID
RESTASK.NAME=JOB.JOB_DESCR
RESTASK.PRIORITY=JOB.JOB_BKG_BTY_ID
RESTASK.ANALYSIS=JOB.JOB_CRD_ID
~MessageBox~
~end of main loop~
~0~
~1~
~Next~
~MessageBox~
~0~
~1~
~Next~
~End~
~MessageBox~
~0~
~1~
~Edit INI File~
~SvrCnfg.ini~
~2~
~FieldMap~
~$EachKey$~
~If~
~EachKey~
~1~
~JOB~
~TRUE~
~For Each~
~EachKey~
~$EachLine$~
~For Each~
~EachLine~
~$NEWLINE$~
~Parse String~
~$NEWLINE$~
~FieldMapSettings2~
~0~
~FALSE~
~FALSE~
~Parse String~
~[FieldMap]~
~FieldMapSettings1~
~0~
~FALSE~
~TRUE~
~FieldMapSettings~
~Test~
[FieldMap]
Let me check.
Francesco
Francesco
Dear Samira,
Please have a look at the attached project.
The project stores the original INI file under SUPPORTDIR, copies it to C:\Mytest and then executes the ini entries removal.
NOTE!
The "Edit INI FILE" is a Windows Installer command (purple command) and due of this, its execution is deferred to Apply Install Execution.
With my sample I used NATIVE ENGINE to execute the command immediately.
NOTE!
- TestIni.rar
- (2.16 MiB) Downloaded 535 times
Dear FrancescoT
Thanks a lot. It works now
Happy you solved!
