Vista TaskDialog
jls
Vista TaskDialog
Postby jls » Fri Jun 15, 2007 2:36 am
I have created a TaskDialog just to test if it work.
Maybe I will create a plugin, but the dll seems to work.
Currently I have made this interface:
function ShowInformation(Title : PChar;Instruction : PChar;Content: PChar): boolean; stdcall;
function ShowWarning(Title : PChar;Instruction : PChar;Content: PChar): boolean; stdcall;
function ShowQuestion(Title : PChar;Instruction : PChar;Content: PChar): boolean; stdcall;
function ShowRadioButtonQuestion(Title : PChar;Instruction : PChar;Content: PChar;Radiobuttons : PChar): integer; stdcall;
ShowRadioButtonQuestion:
Radiobuttons is a comma separated list
Return values are:
0 if you select NO
201,202.... if you select on of the radiobuttons
The dialog works on all windows versions.
Jørgen Storlie
Postby MichaelNesmith » Sat Jun 16, 2007 8:57 pm
Thank you for sharing the news of your Vista Task Dialog DLL! It would be great if you could post the DLL here as a ZIP attachment, so other users can also benefit from it.
Also, a question I have is, how is the task dialog implemented on platforms other than Vista? Is it emulated in some form?
jls
Postby jls » Sun Jun 17, 2007 2:00 pm
I have posted the message twice. The dll in uploaded in the other message.
The DLL is created in Delphi. I have used TAdvTaskDialog from tmssoftware.
Is is emulated on non Vista platforms.
It is easy to support more of the features if the task dialog e.g. command buttons more info text....
Users browsing this forum: No registered users and 53 guests
