Upload Plug-In for InstallAware
Postby Maros » Fri Jun 15, 2007 6:24 am
The Upload Plug-In allows you to upload files during setup or update process. So you can track your software installations or updates.
Generally you can send any file over http to internet during setup using this Plug-In.
More information and download is here:
Just let me know if you have any comments or questions.
Postby MichaelNesmith » Sat Jun 16, 2007 9:17 pm
Thanks for this wonderful plug-in!
Do you also have progress feedback during lengthy uploads? Does the plug-in support cancelling an operation?
Postby Maros » Sun Jun 17, 2007 2:32 pm
Hello Michael,
Currently these features are not implemented but if the Plug-In gets a little bit popular we can implement them as well.
In current version there is no end-user interaction at all during the setup - upload process. The setup developer only defines parameters and then when setup is running everything is made without any user interaction.
Best Regards,
Maros Matusek
Interaza Team, http://software.interaza.com
Users browsing this forum: No registered users and 1 guest
