Sorry for bothering again. Do you think you can have this plugin ready this week or is there any other way to do the application creation for a virtual folder?
Regards,
paulo
Script for setting up an Application Pool in IIS
HI,
Setting the ASP.NET version for the virtual directory can be done also by calling the Run Program command. Use parameters:
Run Program:
$WINDIR$\\Microsoft.NET\\Framework\\v2.0.50727\\aspnet_regiis.exe
Command Line Parameters:
-s W3SVC/1/ROOT/WEBDIRNAME
Change the WEBDIRNAME to you virtual folder name.
This works fine with my installer - it is changing from the default ASP.NET 1.1 to 2.0
Hope this helps.
Run Program:
Hope this helps.
liambrennan
Has there been any update in regards to setting a virtual directory to an application pool? I am aware that I can specify an application pool in the virtual directory properties but what i would like to do is to present the user with a list of current application pools and give them the option of selecting one, is this functionality available?
Liam.
Liam.
Re: Script for setting up an Application Pool in IIS
It's 2016, 10 years later, can't see a way to set the user for an app pool, or even configure any app pool settings. Is this possible in X4?
All App Pool settings can be issued via "appcmd.exe" and this can be easily done via IA script.
Have a look at the Microsoft documentation for more details.
