Script for setting up an Application Pool in IIS
Do you have any sample scripts, that would install the application pool and relate it to the virtual directory, created by the InstallAware build in action?
Andrej.
Andrej.
What I would like to achieve is create a new Application Pool (I need it because my ASP.NET application is using a COM service, that requires running under special user account). After it is created, I would connect the virtual directory to the newly created application pool.
In the Application Properties section I also do not see an option to set Application Pool. I do not want just to create Application, but the Application pool. Maybe I am missing something?
Thank you.
Thank you.
I'm using the trial version of InstallAware and this is the only point which is causing me trouble. I really need to create a new Application on a Virtual Directory on IIS 5.1 and it always sets the Application Pool to DefaultAppPool.
Do you have any estimates when the plugin will be released? Our application needs to be ready for next week!
Thanks in advance for your help. And congratulations for a great product.
Kind regards,
paulo
Kind regards,
paulo
Hi Paulo,
Could you please explain in a little more detail what you mean?
Are you asking for the capability to check for a specific ASP.NET version?
How is this related to virtual directories?
Please let me know in detail - and I'll make sure it gets action!
Hello Michael,
I am referring to the fact that when you create a website or virtual directory for ASP.NET you can assign a specific .NET framework version to be used for that website / vdir. That way, you can have multiple ASP.NET websites running different framework versions.
However, if you have both frameworks installed, 1.1 and 2.0, when you create a website / vdir it defaults for 1.1, and you have to change it manually to 2.0 if you are putting a 2.0 ASP.NET application there. So it would be nice to automate this in the installation. This can be done manually in IIS Manager in the website / vdir Properties in the ASP.NET tab.
Thank you for your attention.
Regards,
Paulo[/img]
Regards,
Paulo[/img]
