I need to be able to uninstall files extracted from zip file
RyanWagner
Postby RyanWagner » Fri May 16, 2014 1:10 pm
I'm extracting files from a winrar/zip archive to the $TARGETDIR$ directory in the MSIcode.
I would like to have these extracted files uninstalled when the user uninstalls the program from control panel.
Is this possible?
Examples of extracting files from zip file:
Run Program $SUPPORTDIR$\UnRAR.exe e -ppassword -o+ -y "$EXEDIR$\myarchive.rar" "$TARGETDIR$" (WAIT, get result into variable SUCCESS)
Or using:
Extract 7Zip Archive $EXEDIR$\myarchive.rar into folder $TARGETDIR$ (get result into variable SUCCESS)
I found a message board post from 2010 that said it wasn't possible hopefully its possible with the latest version of InstallAware as we absolutely need to have these files deleted on uninstallation of product.
viewtopic.php?f=2&t=7863
RyanWagner
Re: I need to be able to uninstall files extracted from zip
Postby RyanWagner » Fri May 16, 2014 3:56 pm
Okay, I have a solution but its just a work around for the problem. I create a empty text file when I first install product and populate it with the filenames of the files I'm unzipping to target directory.
I then read this file when the product uninstalls and delete each file listed in the textfile. This works but there really should be a better way.
The InstallAware installer should take care of uninstalling these files.
Postby FrancescoT » Mon May 19, 2014 7:16 am
Dear Ryan,
in reality the post you mention already has the answer to your question.
You need to run the files deletion upon un-install.
This because the extracted files are not part of the Windows Installer database sequence and consequently, they will not be removed at un-install by the MSI engine ... it is not an IA limitation.
Anyway, you can easily delete them using the "Delete Files" command at the end of the un-install sequence in your main script.
Note, the "Delete Files" command is a Windows Installer command (purple command) and normally deferred to Apply Install /Un-install execution.
Due of this, you need to call the command within a Native Engine ON/OFF sequence to execute it immediately.
Example;
Delete Files ....
Users browsing this forum: No registered users and 99 guests
