How do I fix this error?
Cleared output folder G:\abc\WS\WSUpdate\Release\SingleBuilt plug-in action Download File
Built plug-in action Windows Installer
Built plug-in action (Un)Install MSI Setup
Error during build: Access violation at address 00000000. Read of address 00000000
error when building access violation
Re: error when building access violation
did you check if the following post can help you?
http://www.installaware.com/forum/viewtopic.php?f=2&t=8908
Tried all of the suggestion with same result. I re-installed Installaware and re-installed the additional plugins Im using same results. is there a way for installaware to identify the issue?
CJB
CJB
Dear CJB,
did you try to verify if the cause is the Anti-Virus (if any)?
Users browsing this forum: No registered users and 129 guests
