My installer sets up a MS SQL data base, prompts the technician to acknowledge some release notes and then installs the program. When uninstalling the program, either from the menu option or the control panel it wants to run the MS SQL install portion. I have this section at the beginning of the install so that the software can not be installed if the data base is not installed. I attempted using the following variables: MAINTENANCE, UNINSTALLLINK, REMOVEOLD,NEDSUPGRADE, and NEWINSTANCE.
What I am trying to do is the following:
IF this is an install (not an upgrade, maintenance or uninstall)
RUN the SQL scripts
GET the release notes acknowledgement
INSTALL the program
ELSE
Uninstall the program
END
The above mentioned variables have not assisted me in this goal. I have read through the Pre-Defined Variables list as well which did not give me an answer either. Thanks in advance for any assistance that can be provided.
Uninstall and re-install/maintenance
Re: Uninstall and re-install/maintenance
I found in the MSI code snippets under System Information "Does File/Folder Exist". I used this to set a flag telling me weather the program was installed already or not. This has solved my problem.
James
James
Dear James,
I am happy that you solved.
Anyway, if you check the value of NEDSUPGRADE and MAINTENANCE you can easily know if your package has been already installed.
NEEDSUPGRADE: TRUE if a previous version of the product was found installed using the Windows Installer engine, FALSE otherwise.
MAINTENANCE: Initially TRUE if the same version of the application has been installed before, FALSE otherwise.
Hello Francesco,
I attempted using NEDSUPGRADE and MAINTENANCE. In fact MAINTENANCE is the variable I chose to set if the file path existed. I am probably doing something wrong but this variable shows up FALSE for me even if the software is already installed.
The NEDSUPGRADE variable reliably shows TRUE if a new build of the installer is used. However if the same installer is used to uninstall or re-install an instance of our software it comes up FALSE.
Please let me know if you would like me to send an e-mail with a copy of my project code in it to you.
Also thanks for always quickly responding and helping people like me out. It is greatly appreciated.
Sincerely
James
Sincerely
James
Dear James,
When NEEDSUPGRADE is FALSE you have to check also the MAINTENANCE variable value.
Example;
The NEEDSUPGRADE variable reliably shows TRUE if a new build of the installer is used. However if the same installer is used to uninstall or re-install an instance of our software it comes up FALSE.
Example;
if Variable NEEDSUPGRADE Equals FALSE
if Variable MAINTENANCE Equals TRUE
Comment: SAME PRODUCT VERSION ALREADY INSTALLED
else
Comment: NONE INSTALLED
else
Comment: PREVIOUS PRODUCT VERSION ALREADY INSTALLED
Users browsing this forum: Google [Bot] and 86 guests
