Multi-Language Build
mwilner
Post by mwilner »
I have an interesting problem.
I use the native_engine build for immediate processing of the installation commands.
When I am building a multi-language build as a debug build it works and shows the language selection dialog.
But when I am building as a single file compressed build it will not show the language selection dialog.
Can you explain what is going on?
Thank you,
Manfred Wilner
Re: Multi-Language Build
Dear Manfred,
it's really difficult to share with you a possible suggestion without having your project.
Did you try to re-import back all resource strings and then to rebuild your project?
