I'm testing out patching with IA 18. I started with an existing project that was released. I set the power tweak on balanced and always cache sources checked. I build the project as a single EXE and moved the EXE to another folder. I then added a simple EXE to the project in a existing folder. I added the first build from the above steps to the Patches area and clicked Patch on the ribbon. I almost immediately get an error "LABEL undefined: destination Directory". I click OK and the program selects "Goto Label: Destination Directory" and pop's up the Goto Label selection dialog. When I look at the MSI Code section, the capitalization is correct.
Considering how little I changed in the project, why is this failing? I couldn't find this issue anywhere online or in this forum. If you need me to post code, just let me know.
Matt
Patching: Label undefined error
Re: Patching: Label undefined error
Dear Math,
I suggest you as first, to have a look at following topics where are available useful information on how to avoid common errors with patch creation.
Note, it is also available a ready to use sample project with the second link below.
http://www.installaware.com/forum/viewt ... lit=+patch
http://www.installaware.com/forum/viewt ... f=2&t=8697
let me know if you still have problems.
