Direct Deploy Issues
yflint
Postby yflint » Thu Jun 12, 2014 5:15 am
I have been trying the new /ddq option and I have found two major issues that are preventing me from using this feature:
1. when selecting a machine from one of the lists and pressing install/uninstall , the installer only scans the network again and doesn't do anything else.
2. At the list of "installed on systems" , not all the machines with my program installed on them appear in the list.
Have you encountered these issues?
Re: Direct Deploy Issues
Postby FrancescoT » Thu Jun 12, 2014 7:52 am
Dear Yflint,
Did you try to Query your network once again or even more?
yflint
Postby yflint » Thu Jun 12, 2014 8:02 am
Yes, of course. the same thing happens over and over.
Postby FrancescoT » Thu Jun 12, 2014 8:06 am
Dear Yflint,
Did you try to use the Debugger over the "DirectDeploy" script?
Alternatively, you could use some Message-Boxes to monitor the effective script code executed or to evaluate return codes condition.
Users browsing this forum: vaibhavopkey and 127 guests
