Windows 8.1 Update 1
pokr2
Post by pokr2 »
Is there a way to distinguish between Windows 8.1 with and without the Update 1? The Get OS Level function returns METROR2 and 0 for OS and SP Level in both cases...
I'm using IA 18.
Thanks, regards,
Octavio
Re: Windows 8.1 Update 1
Dear Octavio,
unfortunately, WIN 8.1 was not available when IA 18 has been released and due the fact that WIN 8.1 is not a service pack ... you can't use that commnads to verify if your target is a WIN 8.1 OS.
However, you can use one of the following WINAPI to do the same via "Call DLL" command.
http://msdn.microsoft.com/en-us/library ... s.85).aspx
