installation of the prerequisite on a 64-bit Windows 7 Pro (VMWare.) virtual machine.
The error occurs during the start of the installation of .NET Framework 4.5 (x64) - (I haven't tried x86 yet.)
The full error is:
If I attempt to run the "setup.exe" in the unpacked filebag (to get more info.),"Microsoft .NET Framework 4.5 could not be installed. The system
cannot find the path specified
Please use Windows Update to manually install this update on your
system.
Setup cannot continue."
I get a .NET setup error saying that "You cannot use this setup program to install the .NET Framework."
I can only surmise from the MSDN article;
http://msdn.microsoft.com/en-us/library ... .110).aspx
that the issue has something to do with .NET 4.5.1 being available as an Important update in Windows Update,
though I've taken steps to make sure .NET 4.5 is not installed, all other Windows Updates have been applied and .NET 3.5 and 4.0 are installed.
If I try to install .NET 4.5 from Microsoft's Web Installer or Windows update, it installs fine.
Is this a bug in InstallAwares' ".NET Framework 4.5" redistribution as a result of the recent(ish) release of .NET 4.5.1 as a Windows Update,
or is there something else I'm missing?
Regards,
- Aaron.
