Installer Error about supposingly missing file
mwilner
Post by mwilner »
I am experiencing occasionally that customers complain about an error that a file that should be installed to System32 or SYSWow64 can't be read or found.
What can cause this error on some PC's (in this case Win 7 and Win 8 x64) but not on most others with the same OS flavor?
Hope you can shed some light on this.
Best regards,
Installer error
Installer error
Manfred Wilner
Re: Installer Error about supposingly missing file
did you check if any anti-virus application or security policy, it is causing this problem on those machines?
heyitshannes
Post by heyitshannes »
I am also experiencing this issue. The compile of my installer runs file, but when I try install, the installer says that there are files missing. I have removed the files in my InstallAware project and re-added them, but with no luck.
The machine I'm trying to install on is a fresh Windows 7 32-bit on a Virtual Machine. No antivirus or anything. The installer was created using InstallAware Studio 15.
Please help. ^_^
if you post a very minimal project that replicates your issue, I'll try to verify it.
heyitshannes
Hi Francesco
Here is the project in question. I hope you will be able to help.
Hannes
Installer.zip
(1.38 MiB) Downloaded 410 times
Dear Hannes,
I'll be back to you as soon as possible.
Dear Hannes,
to test your package, I need to receive all the files used by your project ... otherwise, I'll be not able to compile it.
Please also check if you can release a very minimal project that replicates your issue, instead of sending your original one.
In any case, please don't forget to include all the files used.
