Dear,
I am testing Installaware Express, before purchasing the license. I wonder if anyone has already encountered this problem, and can suggest a solution. I am building my application setup and continuously encounter this error:
"Error during build: Cannot open file "C:\Program Files (x86)\Reference Assemblies\Microsoft\VBPowerPacks\v10.0\Microsoft.VisualBasic.PowerPacks.Vs.dll". The process cannot access the file because it is being used by another process"
I am using Visual Studio 2010 and C#. In my Visual Studio, I also have InstallShield plug-in , as well as Installaware.
See in attachment the setup log file.
Thanks in advance.
Regards,
Patrick M.
- dBm Planner.log
- (1.17 KiB) Downloaded 518 times
Re: Microsoft.VisualBasic.PowerPacks.Vs.dll
Dear Pmambo,
Did you verify if any other process is using your DLL when IA tries to build your package?
Did you try to manually copy that file under a different folder?
Hi Francesco,
Thanks for your reply. Let me try that. I'll get back to you.
