I would like to include the SQL CE 4.0 SP1 Runtime with my application. I see that InstallAware 18 includes support for SQL CE 4.0 but not for SQL CE 4.0 SP1. When I run my installer on a computer which already has SQL CE 4.0 SP1 installed, InstallAware attempts to run the SQL CE 4.0 setup, and that setup tells me that it can't proceed because I already have a newer version installed.
I looked at the script file which determines if SQL CE 4.0 SP1 is already installed, and I see it's checking for a GUID. So presumably, I could change that GUID and have it test for SQL CE 4.0 SP1 instead. I'm not sure what to change the GUID to, though. Can someone help?
Also, is there a way for me to create my own entries in the Application Runtimes list in InstallAware? Once I create a script for SQL SC 4.0 SP1, I'd like it to persist so I can use it in future installations.
Thank you in advance for any help you can provide.
Re: SQL CE 4.0 SP1 Runtime
Dear Eric,
To verify this, you should first install SQL CE 4.0 SP1 on a test machine and then to inspect the "GUID" created under registry at "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" for the package.I looked at the script file which determines if SQL CE 4.0 SP1 is already installed, and I see it's checking for a GUID. So presumably, I could change that GUID and have it test for SQL CE 4.0 SP1 instead. I'm not sure what to change the GUID to, though. Can someone help?
Please have a look at the document "Extending the Application Runtimes View" available from; http://www.installaware.com/publication ... papers.htmAlso, is there a way for me to create my own entries in the Application Runtimes list in InstallAware? Once I create a script for SQL SC 4.0 SP1, I'd like it to persist so I can use it in future installations.
