NXCheck and DBCheck
Joc02
NXCheck and DBCheck
Postby Joc02 » Mon Jul 21, 2014 1:16 am
I try to certified my applicaiton with Microsoft. And I've 2 errors with the setup (Aranaud.exe) generate by InstallAware
It's the log file :
•type : BinScopeRunSettings
•logTime : 2014-07-18T09:20:18.9584057+02:00
Failed checks
•C:\Temp\Arnaud.exe - NXCheck ( FAIL )
?Information : Image is not marked as NX compatible
•C:\Temp\Arnaud.exe - DBCheck ( FAIL )
?Information : Image is not marked as Dynamic Base compatible
Checks that didn't complete
Are you any idea's ?
Re: NXCheck and DBCheck
Postby FrancescoT » Mon Jul 21, 2014 10:44 am
... which IA version are you using? ... which certification program are you trying to apply?
sanderi
Postby sanderi » Tue Sep 09, 2014 7:29 am
Iam running into the same issue.
I am using InstallAware 14 and I need to use Microsoft "Platform ready" suite to test my application for Windows Server 2012 R2.
Any help to resolve this would be greatly appreciated,
Joel
Postby FrancescoT » Tue Sep 09, 2014 11:22 am
Dear Joel,
please refere to my reply to your similar question you posted with the thread below.
http://www.installaware.com/forum/viewtopic.php?f=2&t=10086&p=37963#p37963
sanderi
Postby sanderi » Mon Sep 15, 2014 8:01 am
Hi, I tried this but unfortunately the problem seems to be unrelated.
These are the exact error messages I get from the validation tool:
Postby FrancescoT » Mon Sep 15, 2014 11:39 am
Dear Joel,
does it happens even if you try to validate a dummy installer (...without adding any file to the project) generated using the latest IA 18 version?
sanderi
Postby sanderi » Tue Sep 16, 2014 5:03 am
Hi Francesco,
I tried this now, but the problem persist.
What I did was to create a new project using the Quick start wizard. I made the application folder only consist of a small .txt-file to make the installation as simple as possible. Then I created a Single File MSI.
I ran the platform check with this small msi-file but again it failed with the same error message.
The platform ready-tool for Windows Server 2012 R2 (from January this year) is available for download at
http://www.microsoft.com/en-us/download ... x?id=41676
so you can also try it out yourself.
I would really appreciate any help on this matter. Certifying our application with Microsoft is a big deal for us.
Best regards,
- Joel Sanderi
Postby FrancescoT » Tue Sep 16, 2014 11:49 am
Dear Joel,
let me check it.
sanderi
Postby sanderi » Thu Sep 25, 2014 7:54 am
Hello Francesco, when can I expect to get an update on this matter?
Best Regards,
Joel
Postby FrancescoT » Thu Sep 25, 2014 10:09 am
Dear Joel,
unfortunately, not yet!
I'll be back on this as soon I have any news
iinatti
Postby iinatti » Tue Dec 02, 2014 11:36 pm
Passing these should not be mandatory.
http://go.microsoft.com/fwlink/?LinkID=311590
3.2 Applications must comply with Windows security requirements
Note: This test case is a Microsoft recommended Best Practice and is not required for passing the Certification Program.
Users browsing this forum: No registered users and 16 guests
