\"Browse for Folder\" Issue
MarkRichards
Postby MarkRichards » Mon Jul 03, 2006 1:53 pm
I've got extremely complex application install requirements, and so I use InstallAware v5.3 to "bootstrap" the machine environment (with .NET 2.0 & MSI 3.1) and then launch immediately into a custom installer module. The custom installer modules are included with the InstallAware package as support files. I need to launch the custom code during BOTH installation and removal.
Installation is working perfectly - my custom code is launched and (if it proceeds without), the installation is finalized. But during UN-install, I have a weird problem: a "Browse for Folder" pops up immediately before my custom code launches.
I can't figure out why this is happening. The custom modules still do launch correctly, so I don't know what the installation package is even trying to browse for.
Here's the call block:
Set Variable OSSetupResult to
if Variable REMOVE Equals TRUE
Run Program $SUPPORTDIR$\\custom_install.exe remove (WAIT)
else
Run Program $SUPPORTDIR$\\custom_install.exe (WAIT)
Any ideas on what I'm doing wrong here?
- Mark R.
Postby MichaelNesmith » Mon Jul 03, 2006 1:58 pm
Hi Mark!
Do you have any plug-in calls that may require access to source media, such as File Bag, that execute during uninstall?
MarkRichards
Postby MarkRichards » Mon Jul 03, 2006 2:40 pm
Hi Michael,
Thanks for the quick reply. You folks do a great job.
To answer your question - nope, I'm not use file bags or any other plug-ins. I do have the MSI 3.1 and .NET 2.0 pre-requisites turned on.
The "Browse for Folder" dialog appears right before my custom installer app launches, but only during un-install. This implies to me that the problem is related to the support files somehow, but I'm at a loss as to why.
Nothing much else of interest in the project, really.
- Mark R.
MarkRichards
Postby MarkRichards » Mon Jul 03, 2006 2:50 pm
I figured it out.
I had a stray "Apply Install" command sitting up above my un-install logic. For whatever reason (and I'm sure there's a sensible one) this was kicking off the "Browse for Folder" dialog during un-install.
I added some conditional logic and the problem is resolved.
Thanks again for the help.
- Mark R.
Postby MichaelNesmith » Mon Jul 03, 2006 4:07 pm
Hi!
Apply Install does require access to source media, as its trying to install files - that explains it. Glad you have it figured out!
Users browsing this forum: Bing [Bot] and 54 guests
