Error during build with code signing
Frank
Postby Frank » Fri Jul 25, 2014 2:51 am
During build I see the following message:
"Error during build: Unable to create temporary code of file for out-of-place code signing: somefile.exe"
If build the project again and I get the same message but on a different file.
After some attempts it will actually run all the way and create an (signed) installer.
I'm logged on as local administator so my access to "C:\Users\MyName\AppData\Local\Temp\Q___Releases_SomeProduct\" is no issue.
Having to restart IA (IA18.Build 6.2.14) or click "Build" over and over again is annoying.
Can you help diagnose this issue?
Kind regards,
Frank
Re: Error during build with code signing
Postby FrancescoT » Fri Jul 25, 2014 10:36 am
Dear Frank,
First try to upgrade to the latest IA 18 version (18.08), then if the problem persist, send to me a project that replicates the issue.
Frank
Postby Frank » Tue Jul 29, 2014 1:57 am
Hi Francesco,
I've updated the version but it still occurs. If I use miabuild.exe instead of the GUI it never happens (which does make for a good alternative).
What files would you like to receive?
The project, it's scripts and the dialogs? So not the executables and dlls and stuff, which I guess will be stubbed?
As you will understand, I'm not sending our code signing certificate :D
Kind regards,
Frank
Postby FrancescoT » Tue Jul 29, 2014 10:25 am
Dear Frank,
... really strange that it doesn't happen using miabuild directly ... even because the IA IDE uses the miabuild itself.
Can you check if any Anti-Virus application is causing your issue?
Frank
Postby Frank » Wed Jul 30, 2014 8:39 am
Spoke to soon...
This is (part of) the output of the command-line:
Copied file C:\Users\fkaaijk\AppData\Local\Temp\Q___Release_components\XYAddPS.dll
Error during build: Unable to create temporary copy of file for out-of-place code signing: XYXDSLib.dll
I check the anti-virus suggestion.
Postby FrancescoT » Wed Jul 30, 2014 11:26 am
This makes much more sense (.... even if it still doesn't solve your problem).
Let me know.
Users browsing this forum: No registered users and 90 guests
