Finding a substring
Finding a substring
I am looking for the best way to find if a substring exists. I have read in an XML file to a variable $XMLFile$. I have another file with a series of keys. I was planning to scan the $XMLFIle$ for each key using a while not EOF loop. Parse String does not appear to provide a FOUND type value. If not found, will Parse String always put the entire sting in the "Variable for Second Part" and Leave the "Variable for First Part" blank? Thanks, Adrian.
Re: Finding a substring
Dear Adrian,
Did you try with using the IF statement along the "Contains" comparison option?
The sample below checks if MYVARIABLE contains "/update";
if Variable MYVARIABLE Contains /update
Perfect, exactly what I was after.
Users browsing this forum: No registered users and 85 guests
