Several Product GUIDs are created
albainr
Post by albainr »
Here is my scenario:
A main installer(Installaware based, web-install, EXE with an MSI inside) calls another one(also InstallAware based, single file, MSI instead of EXE).
Basically, the content of the main changes and the second stays pretty much the same or barely changes.
The main installer embeds into his FileBag the second one and other MSIs.
Here are behaviors:
Every time user installs the main one, it checks if there is a version of the second and install/uninstalls it accordingly.
If the second is already installed, the main ask the second to uninstall itself and this is where I have issues.
Issues description:
I got error messages explaining that the second cannot be install because the local temp folder is missing(previous location where the installer was installed from).
My searches:
To isolate the case, I ran the second installer manually (install/uninstall).
I noticed that in HKEY_CURRENT_USER\Software\Microsoft\Installer\Products\<product code> two entries are created for the same product. The correct one(or almost the correct one)
A947671A17337F64CA69CFF459D8270F kind of an anagram of
A176749A337146F7AC96FC4F958D72F0 (This is the correct one recorded inside the Project Properties page)
and another one
3316EE3DF0621BE4EB61AB73D858F38C ????
In windows Install/Uninstall prog and features, There is one entry but internally, the MSI engine detects 2 entries for this product. I checked it with the help of the Microsoft tool MicrosoftFixit.ProgramInstallUninstall.MATSKB.Run.exe available from MS website.
Here are my questions:
1) Please can you let me know why this second GUID is not uninstall properly???
2) What can I do to uninstall the second product properly???
If you need more information on my side or if something is not clear, feel free to let me know.
P.S.:
I forgot to mention that under HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{GUID}, UninstallSource is C:\Users\albainr.DP_CORP\AppData\Local\Temp\mia1\.
There is no UninstallString with the famous "msiexec /x {GUID}". Should I add it or by default it uses InstallSource?
Re: Several Product GUIDs are created
First of all, if you try to run separately all those installers (the ones currently embedded with your main installer), are them installed correctly?
The InstallSource string is used .... it is not necessary to add anything else.
Let me know.
