Copy Move Local Files Issue
jcassidy
Postby jcassidy » Tue Aug 12, 2014 10:18 am
My requirement is to create a unique folder to backup to and then move the existing files into this folder. To do so I have attempted multiple configurations of the below code.
Does Folder Exist C:\RMT\ (get result into variable OLDRMTEXISTS)
if Variable OLDRMTEXISTS Equals TRUE
    Set Variable MYDATE to $DATE$
    Replace / with _ in variable MYDATE
    Set Variable MYDIR to C:\RMT$MYDATE$
    Create Folder $MYDIR$
    Apply Install (get result into variable MYSUCCESS)
    Copy Local Files C:\RMT\*.* to $MYDIR$\*.* (include subfolders)
No matter what I do and how I configure this the files and folders do not copy. I end up with an empty folder with the correct name.
Also once I start moving things around or chance the copy local files command not even the folder is created which forces me to create a new project while copying and pasting the existing code.
Without change to the code and pasting it into the new project the folder creation works again but I am still unable to get the files and folders to copy over to the new destination.
Things I have attempted:
    * Having only one apply after the create directory and copy local files command.
    * Removing the wild card *.* from the files field.
    * Removing the create folder, creating the folder manually, running the copy local file command followed by the apply install.
    * Changing from SUCCESS to MYSUCCESS (did not think this would do anything but worth ruling out.)
There must be something that I am missing. The only really frustrating part about this however is that I had to create over 9 different projects to get this far. Working with this feature caused the Apply Install command to be corrupted for the whole installer which resulted in the creation of multiple new projects.
Any guidance other than the current forum posts and available documentation would be appreciated as I scoured these resources prior to posting this message.
James
Re: Copy Move Local Files Issue
Postby FrancescoT » Tue Aug 12, 2014 11:18 am
Dear James,
try the following instead;
I suppose that your problem is caused by the multiple calls to Apply Install ( ... which it is not recommended in your case) and by the "include subfolders" flag with the "Copy Local Files" command. The flag only works when used with NATIVE ENGINE ... otherwise it's ignored.
jcassidy
Postby jcassidy » Tue Aug 12, 2014 11:25 am
Hello Francesco,
This works great! This also clears up what is meant by the NATIVE_ENGINE as well.
As always thanks for the expeditious assistance.
Sincerely
James
Postby FrancescoT » Tue Aug 12, 2014 11:30 am
I'm happy you solved :D !
Users browsing this forum: No registered users and 20 guests
