Write Registry Persist
AdrianGray
Post by AdrianGray »
Is there a way to write the value of variable into "String Value Data (REG_SZ) dialog? Is there a later version than the IA 9 one I have installed. Thanks, Adrian
Re: Write Registry Persist
Dear Adrian,
If I haven't missed anything... I suppose you want to pass a variable with the write registry command.
If true, the syntax for dereferencing a variable in InstallAware is enclosing the variable name between dollar signs. For instance, if the variable is called MYVAR, dereference the variable using $MYVAR$. You may freely combine multiple dereferenced variables in your string literals.
The latest version is InstallAware 18.
NOTE this topic has been moved to the more pertinent "Technical Support" forum.
AdrianGray
Sorry for the confusion. I was referring to the Plugin: "Write Registry Persist" being for IA9, we are running IA18 for development. I have since managed to successfully use the inbuilt "Write Registry" function instead. Thanks, Adrian.
:D
