Question regarding "Find all files"
anja_laenge
Postby anja_laenge » Mon Aug 18, 2014 4:07 am
how do I have to use the Find all Files command to combine several search options?
In windows explorer I can use <"setup" OR *.xlsx> (without brackets) to find all files of type .xlsx or containing the phrase "setup". How can I do this for a folder <d:\_projects> ?
Thanks in advance
Anja
Re: Question regarding "Find all files"
Postby FrancescoT » Mon Aug 18, 2014 9:25 am
Dear Anja,
The Find all Files command only searches for files "names" ... and not for files content.
anja_laenge
Postby anja_laenge » Fri Aug 22, 2014 12:47 am
FrancescoT wrote:Dear Anja,
When you open a windows explorer and enter <setup OR .xlsx> without the brackets into the search field it will find all files containing one of those phrases in the fileNAME, not the fileCONTENT. I want to use this functionality in an InstallAware setup. Otherwise I would have to do several searches which could take quite a while when there are 2 GB to be searched.
Is this possible? If so, how?
Anja
Postby FrancescoT » Fri Aug 22, 2014 7:22 am
Dear Anja,
due the fact that you said " ... to find all files of type .xlsx or containing the phrase "setup." ... I misunderstood your question.
The "Find all Files" command allows wildcard, so you could try;
- d:\_projects\*.xlsx to match all files with XLSX extension
or
- d:\_projects\*setup* to match all files with "setup" in their names
PLEASE NOTE!
If multiple file names match, the returned file names are delimited by the | character. If some of the returned files contain embedded spaces, those file names will additionally be wrapped inside double quote " characters.
anja_laenge
Postby anja_laenge » Fri Aug 22, 2014 7:31 am
or
Okay, thank you.
Does this mean, I can not combine two searches via OR?
Anja
Postby FrancescoT » Fri Aug 22, 2014 10:08 am
Unfortunately, you can't.
Users browsing this forum: No registered users and 85 guests
