I have an issue whereby I read a web.config into a variable using "Read from TextFile" When I display the associated variable, the UNC paths show correctly. I then parse the string twice to remove a section, recreating it with a "Set Variable to" First Part + Second Part. This process changes the UNC paths \\server... to \server...
Is there a way to prevent this from happening. Thanks, Adrian
Parse String destroying UNC paths
Re: Parse String destroying UNC paths
Dear Adrian,
please have a look at this link; http://www.installaware.com/forum/viewtopic.php?f=2&t=10008&start=0&hilit=UNC
Users browsing this forum: No registered users and 82 guests
