create shortcut for uninstall
Rulan
Post by Rulan »
simple question..
1) Is it possible to create shortcut to make an uninstall of a installed product by clicking on the icon?
2) Or is it possible to install an "uninstall.exe" together with the files in the folder of the installed software?
Re: create shortcut for uninstall
Dear Rulan,
just create a shortcut that points to the value of UNINSTALLLINK pre-defined variable.
For example;
~InstallAware Clipboard Data~
~Create Shortcut~
~{A4D01994-D7C1-4148-970D-BB0A32313887}~
~$UNINSTALLLINK$~
~Uninstall #TITLE#~
~$SHORTCUTFOLDER$~
~Removes this InstallAware Software Corporation product~
~0~
