Hi, is it possible to use variables into "Project Properties/Product Version" field?
I set some variables like:
Set Variable V1 to 2
Set Variable R1 to 1
Set Variable B1 to 15
and I'd like to use them into "Product Version" field but I get various error during install: it seems InstallAware doesn't substitute variables.
I use that variables also for other purposes and everything works fine.
bye
Davide
Project Properties Variables
Hi Davide,
I'd had the same problem.
Unfortuanally i did not found the solution.
See these topics:
http://www.installaware.com/forum/viewtopic.php?t=521
and
http://www.installaware.com/forum/viewt ... ight=#3002
See these topics:
and
Ton Blokhuizen
Tooling Engineer
BMA BV - Netherlands
http://www.bma-mosos.nl[/i]
Tooling Engineer
you can use compiler variables for product version. Simply define a compiler variable like VERS in Project/Options
and use #VERS# to dereference it.
The IDE gives you a warning that you can only enter numbers and periods for product version. Ignore it.
In the same way you can set product name to "My product #VERS#" or assign a variable.
