Hi all,
I have created a project in IA18, which I compile to a single file, and then use the group policy wizard to create a MSI.
When I run the MSI on a 2012 R2 server, I get the error from Windows saying "The system administrator has set policies to prevent this installation". On e.g. a Windows 7, it runs just fine.
I know how to tweak the registry to get it working, but other MSI files runs fine!?! In addition, I have some old MSI made with IA9, they run too! I tried to take a backup project from way back and compile with IA18, but the error persists. I tried creating a project from scratch through the project wizard, but it is the same...
What is my mistake?
--mka
The system administrator has set policies to prevent this...
Re: The system administrator has set policies to prevent thi
Dear Mka,
strange ... for what I know if the "DisableMSI" registry key is enabled, this should prevent to install any MSI package.
mikKummerfeld
We have the Same Problems at a few customers
They have Msi Setups Running but IA Msi are bringing this error
Kind regards
Heiko Kummerfeld
MIK GmbH
Head of quality assurance
technical consultant
Heiko Kummerfeld
MIK GmbH
I found a workaround.
https://social.technet.microsoft.com/Fo ... nservergen
Create a CMD file with the command: msiexec /a MySetup.msi
Run the CMD file as administrator.
Strange as I already am an administrator.
See the log file for a normal run (that fails).
--Martin
Edit: /a doesn't work for me, but /i does.
--Martin
- install.log
- Install log of a normal run
- (60.63 KiB) Downloaded 739 times
Dear Mka,
if UAC is enabled with the OS, you are never an effective administrator ... this is the reason why you have to elevate the process.
The "/a" switch is not allowed with IA ... but you can Always execute an administrative install regardless of using that msiexec switch.
