IA2012-Setups want to connect to 224.0.0.22
pfennig
Post by pfennig »
We are using NATIVE ENGINE for our setups.
Between the extraction and our first dialog form ZoneAlarm reports
the attempt to connect to the Multi Cast IP 224.0.0.22. The setup
continues only after accepting or denying the connection.
What causes this connection attempt and how can we prevent it?
Re: IA2012-Setups want to connect to 224.0.0.22
Dear Pfennig,
I believe there is something else behind the connection attempts you are reporting ... the IA engine doesn't attempt any connection.
