activate installaware 18
JohnWhite
Post by JohnWhite »
i have been using installaware 17 and now need to activate installaware 18
when i log in and try to generate a license using the [Generate License] , the license will not generate and the explorer just errors with Cannot display web page error
Cookies are enabled.
the page i am using to generate the serial number is
Download Purchased Products
Our records indicate you have purchased the following products:
Product Name: InstallAware Studio
On: 7/1/2018
[Download Trial] [Generate License]
[Download Existing License]
bokkie
Re: activate installaware 18
Post by bokkie »
John,
It works okay for me. Perhaps someone out there in the internet put molasses in the engine instead of engine oil. :D
JohnWhite
Post by JohnWhite »
bokkie
thanks
changed oil and it works fine now
Thanks Peter for your ... suggestion.
