HI,
Each time I cut or paste my licencing agreement into "ELLUA and Readme" area and click the save button.... it does not show up once compiled? I have also uploaded an RTF version with no results. When running the installer the licensing agreement is blank and the readme box shows up even though I have excluded it from the dialogues?
Thoughts?
Regards,
Peter
Elua and Readme
Re: Elua and Readme
Dear Peter,
I am not able to replicate what you are reporting.
The text entered or pasted within the EULA/ReadMe view is Always saved correctly (it saves a file under the project folder ... that can be checked using any text editor).
I can only suppose that for some unknow reasons, all you project files are not saved correctly or maybe, there is something that prevents their to be saved correctly.
For example, once you exclude a dialog from the dialogues view and then save the project. is this change applied the next time you load the project?
