HI,
When compiling my project it takes about 45 mins which is not good for developing. I have set the compression to non but have not noticed a difference..... Granted I AM compiling about 750 objects mostly just jpgs that are small. Any help would be greatly appreciated.
Regards,
Peter
Compiling
Re: Compiling
Dear Peter,
I really believe that probably exist something that interferes with the IA functionality ... I suggest you to check if any Anti Virus application may be the cause.
(also considering what you are reporting with your other post http://www.installaware.com/forum/viewt ... =2&t=10121)
