IA X2 / 18 loading scripts
AlejandroNehring
Post by AlejandroNehring »
with IA18 i created a script looking like
Set Variable DIRECTX9C to TRUE
Commet: blablabla
Does Folder Exist $WINDIR$\foldername (get result into variable DIRECTX9C)
if Variable DIRECTX9C Equals TRUE
Set Variable PREREQ to TRUE
Set Variable PRELIST to $PRELIST$$NEWLINE$Microsoft DirectX 9c
In IA X2 it will be displayed as
The comment and the if clause are omitted.
When i try to compile the script, compilation failes because of missing "if"
I uploaded the script checkdx9c.mia
Re: IA X2 / 18 loading scripts
Dear Alejandro,
if you can send/post a project that replicates the issue you are reporting, I'll try to verify it.
At the moment I can only say that I am not able to replicate anything similar.
AlejandroNehring
checkdx9c.zip
Script checkdx9c
(2.43 KiB) Downloaded 469 times
Script checkdx9c does not load correctly
Dear Alejandro,
honestly I really don't what happens on your side.
If I load the script you posted it looks like as below ... and it's seem correct!
Regrads
