Unable to find runtime after X2 upgrade
AdrianGray
Postby AdrianGray » Thu Dec 04, 2014 5:51 am
I have just re-built a project after upgrading to InstallAware X2 and I get an error saying "No files matching wildcard pattern c:\.....\netfx_core_x86\*.*
If you are trying to build application runtimes, run InstallAware setup again, and add all optional features.
I did this the first time and have done so again but I still get the same error. Is it looking at the old runtime path? How can I easily fix this is I have several projects to update. Thanks, Adrian.
Re: Unable to find runtime after X2 upgrade
Postby FrancescoT » Thu Dec 04, 2014 9:35 am
Dear adrian,
please have a look at the steps descibed with the following topic.
http://www.installaware.com/forum/viewtopic.php?f=2&t=10146&start=0
rev23dev
Postby rev23dev » Sat Dec 06, 2014 11:49 am
I tried those steps, downloaded the mFileBag and replaced it, and even redownloaded the entire setup again with no luck.
Even starting a BRAND NEW .NET setup results in the same error.
pro510
Postby pro510 » Mon Dec 08, 2014 1:12 pm
I too am getting the same problem. Replaced the DLL and .NET 4.5 is nowhere to be found in the list of runtimes. 4.5.2 is there, but not 4.5.0
Postby FrancescoT » Tue Dec 09, 2014 9:51 am
Dear Users,
it's not necessary to use the "mFileBag" file available with the post, currently you only need to upgrade to the latest IA version (19.01).
NOTE! You need to re-generate your personal activation file to activate the product.
For what concerns the Runtime error, you only need to follow the steps below (supposing you installed all IA features);
Make a backup of your entire project folder before to proceed!
1- Open the project and remove any used Application Runtime from the project (Design View in the IDE).
2- Remove any Runtime script eventually left (that refers to the used Application runtimes) in the "Include Scripts" node (left tree pane of the MSI code view in IA IDE)
3- Manually check that any "include script" entry (that refers to the removed Application Runtimes) has not been left in your main script.
4- Finally, re-add the required Application Runtimes, save and build the project.
pro510
Postby pro510 » Tue Dec 09, 2014 12:00 pm
I downloaded the latest and it still does not work. .NET Framework 4.5 is not in the list and when I build my project I get the error
C:\PROGRA~2\INSTAL~2\runtimes\netfx_core_x64\*.*"
Postby FrancescoT » Tue Dec 09, 2014 1:39 pm
Could you please send me a project (even a minimal one) that replicates the issue?
pro510
Postby pro510 » Tue Dec 09, 2014 1:53 pm
I sent you an e-mail with the project files zipped up.
rev23dev
Postby rev23dev » Tue Dec 09, 2014 2:40 pm
I'm able to replicate the issue by simply starting a new InstallAware project, and selecting .NET setup. Attempt to build web and I get the error.
Postby FrancescoT » Wed Dec 10, 2014 11:30 am
Dear Rev23dev,
did you installed all IA features?
did you use the latest X2 version available (19.01)?
did you use a re-generated license file to activate the product?
If the problem persist, please contact me at; support@installaware.com
Users browsing this forum: No registered users and 62 guests
