downloaded X2 got my license file,
First problem, in the install dialog it asks for path...
I changed mine from C:\Program Files (x86)\InstallAware X2 to E:\Program Files (x86)\InstallAware X2, notice only the drive letter changed and then I got
Access denied,
that is completely incorrect. It should work and all other programs I have on E also work so why shouldn't InstallAware?
Anyway I said YES to All, and the system continued on it's merry way....until
Second Problem
I noticed after 30 minutes it was still chugging away at 15% CPU...so I cancelled and tried again...
This time, I get a different message in a dialog box:
InstallAware X2 - InstallAware Wizard
Unable to load plug-in library. Please rebuild your project and make sure all required plug-ins are installed.
Action skipped
OK
---------------------------Overall easy but with minor hick-ups...
Only one more question.
How do I change the options to "download" all other options when I'm ready? I picked minimum for this install as I need to find space.
Thanks and best regards
Seán
