My setup project has some included scripts, such as Check MSI 3.0 etc.
I've created a new script, simply by using the right mouse menu "Create New Script"
Then a popup appears in which you have to fill out the name of the script.
I found out that for this particular project I have to make a small change in the script, and do not want to overwrite the current script.
The IA help-file suggest you use the right mouse menu "Save Script File As.."
But for some reason This option is always disabled !?
[we use Version 5.3 (Build b******d_sp3.060314)]
I do not know if the word behind the stars (*) can be posted on this forum....
Menu-option \"Save Script File As\" always disabled
Ton Blokhuizen
Tooling Engineer
BMA BV - Netherlands
http://www.bma-mosos.nl[/i]
Tooling Engineer
Hi Ton,
That option is available only for the master script file (the project script). You can manage include scripts on a file-level using Explorer, and then use remove/add script options to update your project.
