X2 Transition Effects, not working...
SteveDude
Postby SteveDude » Mon Dec 08, 2014 8:36 am
I can't get the transition effects to work. Where are you setting the variables? I tried at the beginning of the script and then I tried after the labels. No luck.
pro510
Re: X2 Transition Effects, not working...
Postby pro510 » Mon Dec 08, 2014 1:16 pm
I didn't have to change anything for the transition effects to work. However, I would also like to know where the setting is so I may turn them off. The transitions are too slow, and this makes it frustrating to click through the pages.
bokkie
Postby bokkie » Mon Dec 08, 2014 3:12 pm
Gentlemen,
Using Set Variable FX to NONE gives me a fast transition through the dialogs. Does that do it for you as well?
If you still want transitions (SteveDude, that appears to be the default) you can set the FXTIME variable to a lesser number of milliseconds than the default of 1000.
Hope that helps.
pfennig
Postby pfennig » Tue Dec 09, 2014 5:37 am
What bokkie writes is correct, but more detailed information can be found under "Pre-defined variables" in the help file.
Best regards
pfennig
SteveDude
Postby SteveDude » Tue Dec 16, 2014 1:42 pm
...I had downloaded some early build of this -19.00- 11/30/2014. Have the latest build an all is working fine. This version is very impressive.
Users browsing this forum: Majestic-12 [Bot] and 118 guests
