Hi Francesco,
I'm trying to run an sql server select command. SELECT x FROM y.
How can I get the returned value?
Regards,
T.
MS SQl Server return selected value
Re: MS SQl Server return selected value
Dear Tzachk,
you could try with using the SQLCMD tool.
http://technet.microsoft.com/en-us/library/ms162773(v=sql.110).aspx
If recall you could save the returned value in a file.
Hi Francesco,
Our server software is not installed on the same machine as the SQL server (that is usual case in most organizations), so using SQLcmd is impossible unless I install additional components which I want to avoid.
Any other way?
Regards,
T.
Any other way?
Regards,
T.
Dear Tzachk,
unfortunately, it doesn't exist any other way ... unless you create a custom DLL or an EXE for such purpose.
Users browsing this forum: No registered users and 89 guests
