Automatically copy file to Output-folder during compiling
Ton_B
Post by Ton_B »
My setup uses 2 external setup-files, which I start using the Run Program function.
These file must be stored in a sub directory of the original setup like this:
\\\\{Servername}\\{Share}\\BMA\\Mosos\\Setup\\MososSetup.msi (this is the main setup)
\\\\{Servername}\\{Share}\\BMA\\Mosos\\Setup\\Components\\dotnetfx.exe
\\\\{Servername}\\{Share}\\BMA\\Mosos\\Setup\\Components\\msxml6.msi
When I Compile my project I need to add these file manually to this sub directory.
Is there a way so the IA Compiler adds these file for me in the output folder?
Ton Blokhuizen
Tooling Engineer
BMA BV - Netherlands
http://www.bma-mosos.nl[/i]
Sorry, no.
You may use a batch file to call the command line build tool, miabuild.exe, and then add the other copy commands.
Additionally, InstallAware is supported by most build utilities, such as NAnt and FinalBuilder.
Tinus
Post by Tinus »
Ton,
I can highly recommend Finalbuilder. Have a look at http://www.finalbuilder.com
Martin Rothschink
AxoNet Software GmbH
