hi
i build installer with installaware 17 and i use single file build that compress
installation.i used runtimes too and installer has folder data beside it.
when i wanna copy it on my external hard drive or on computer on network
path tpp long error raise up
anything i did wrong?
thanks in advance
path too long when wanna copy
Re: path too long when wanna copy
if you built a compressed EXE just remove the data sub-folder (under the Release directory) before to copy the project folder ... it's not necessary to keep such folder.
Users browsing this forum: No registered users and 52 guests
