hi
i put my fonts in $MYFONTS$ and build my setup.
but when i install setup on target machine no font is installed.
any thing else i have to do to install?
i think put fonts in $MYFONTS$ will install fonts.
please help
thanks
Font not install in font folder
Re: Font not install in font folder
Fonts must be installed not only copied, use the "Install Fonts" command.
hi
i installed mdPLUGINS for installaware and
copy my fonts to $TARGETDIR$ and add
after apply install.
after build my setup and install on target machine and excute my app it seems no font is been installed.
did any additional must be done?
by the way what is system font folder in installaware? is it need to copy font to this ?
thanks in advance
Install Fonts from '$TARGETDIR$\Fonts\*.ttf' (remove empty source directory after installation)
thanks in advance
You should contact the Plugin Software vendor directly for any information.
BTW, I have used the same Plug-in many times and Always it worked fine.
Dear Francesco
you did not answer my question.
what font system folder do in installaware?
what happen when we put fonts in this folder?
Dear Mrovvancase,
in reality I have already replied to your question.
"Fonts must be installed not only copied."
The FONT folder in installware doesn't anything of special, obviously ... this is just a system folder as any other system folder available with the target.
Users browsing this forum: No registered users and 87 guests
